Video conversion to STANAG 3550 standard
Hi all,
As you may know, aircraft displays often work with STANAG 3550 video format.
I want to be able to manage RGB SVGA, black&white CCIR and PAL video format, coming from different kind of systems, for an aircraft display.
I need some kind of video converter system, able to input these formats from the external systems, and able to output STANAG 3350 format to the aircraft display.
I found the PMC-704 from Curtis Wright Controls, a mezzanine card, seems to answer to a part of my question.
Do you have some knowledge of video converter systems for use in aircrafts ?
Gilles
