FULL PORT GATE VALVE
I have a question about API 600 Standard. I have to issue a Data sheet for Gate Valves 2"-6" (API 600 Standard). If I want a Full port valve, I need to specify this characteristic or all API 600 Gate Valves are Full Port.
RE: FULL PORT GATE VALVE
"Pumping accounts for 20% of the world's energy used by electric motors and 25-50% of the total electrical energy usage in certain industrial facilities."-DOE statistic (Note: Make that 99% for pipeline companies) http://virtualpipeline.spaces.live.com/
Best Regards
Qalander(Chem)
In this case a gate valve might be better, since it takes more turns to close than a ball valve. The harder it is to close, the more chance nobody will close it.
