HOW DOES THIS WORK IN SEwST ?
I'm trying to get to grips with ST, but I find it really frustrating.
I've created a rotated block on the top plane and put 3 holes in it.
I've dimensioned the holes and now I want to change the position of one hole using the dimensions.
On the attached image If I change the 30 dim to say 28 it cuts off the block and holes as shown on image 2.
Can anyone give an explanation as to why this should be ?
http: //files.en gineering. com/getfil e.aspx?fol der=03863d a3-0863-42 4f-a8c7-b2 e491cf9885 &file= image1.jpg
http: //files.en gineering. com/getfil e.aspx?fol der=a9efda 3d-4597-4b 61-9518-19 f3adc2796e &file= image2.jpg
http:
http:
bc.
2.4GHz Core2 Quad, 4GB RAM,
Quadro FX4600.
RE: HOW DOES THIS WORK IN SEwST ?
could you upload that sample? I quick testcase made did
not show that behaviour and please specify which Liverules
are set active (checkmarked)
dy
http
Default live rules (tangent, parallel & perpendicular UNCHECKED)or live rules suspended it still does it.
Try changing the 24.9 to 25.
Maybe it's something to do with the dimension axis?
bc.
Quadro FX4600.
You guessed it: it's the dimension axis as defined to be the
block's upper left edge. I think it's a bug.
To circumvent:
1) make the small plane at the left grounded
select the face
QuickBar --> Relate
choose Ground
accept by the green checkmark
- or -
2) delete the dimension and recreate it
select either SmartDimension or Distance between
within the command bar --> press 'Lock dimension plane'
select the upper face of the block
set the dimension
after the dimension is created unlock the dimension
plane --> F3 (otherwise it will persist)
ESC to terminate the dimension function
All created dimensions will be created as variable (driven in
non ST-Mode terms). To make them fixed select the dim value and
press the padlock symbol. When changing a dimension pay attention
to the black arrow which indicates the direction of the change.
HTH
dy
method 2) does not require a dimension axis
bc.
Quadro FX4600.
when you've select the plane an selected Relate on the
QuickBar LMB on the rightmost icon and on the 'Flyout'
choose the last icon.
dy
