Still boil-up spreadsheet - Please verifiy
Hi
I have created my own spreadsheet to calculate heat required (KW) to boil up a solvent or solvents selctiable from a table in mole ratios.
But I feel that there is an error in the sheet because the KW are coming out quite high.
I would be greatfull if someon could check and give me feedback on the sheet (posotive or negative)
RE: Still boil-up spreadsheet - Please verifiy
