ASME B16.5 Blind flange with offset connection.
Should a ASME B16.5 blind flange with an offset connection fitted, be considered as a modified flange and calculated in accordance with UG-34 or can it still be classed as a standard component per UG-11(2) if the connection does not exceed the size limits of UG-36(c)(3).
RE: ASME B16.5 Blind flange with offset connection.
jt
