Wind Turbine Foundations
Does anyone have any experience of designing wind turbine foundations, especially the dynamic loads. Looking at both spread and piled FNDs. ANy advice greatly appreciated.
RE: Wind Turbine Foundations
Amy B. Cerato, Ph.D., University of Oklahoma, presented Designing Small Wind Tower Guyed Cable
Foundations Using Helical Anchors Subject
to Dynamic Loads at the DFI seminar in CA. She has done considerable research on it.
Foundation Analysis & Design, Bowles, 1988 edition has Rocking stifness & other dynamic properties. Check, however, with the turbine manufacturer on the allowable range.
In the end, you will need to have the structural designer help with modelling, determining loads per pile, uplift resistance, connection design etc.
Any ideas on estimating settlements under dynamic loads from dynamic stiffness moduli Gd and Ed?
