ASME U stamp Job or T Stamp Job
Dear All:
I have a very special products, a gasoline Tank for the automobile, the detail data:
B. Design Pressure 2,160 kPa (313 psig)
C. Design Temperature 65 C (150° F)
D. Minimum Design Metal -29 C (-20° F) Temperature
E. Service Fluid Propane or LPG
F. Specific Gravity 0.5 @ 24 C (75°F)
G. Corrosion Allowance 0.0 mm
H. Materials per ASME U.P.V. Code, Section II, Division 1,
2007 Edition
Tank Envelope: 305 X 393 X 900 Conformable Tank (Typical)
A. Height: 305 mm (12 in)
B. Width: 393 mm (15.5 in)
C. Length: 900 mm (35.4 in)
D. Type of Head: Multi-piece welded conformable head using
2:1 ellipsoidal profile or one-piece formed head using 2:1
ellipsoidal profile. One-pieced head is shown in drawing.
Now We want apply for the ASME Authorized, but we do not know, which Certificate is suitable for this products, U Stamp or T stamp, If some one knows, If some one knows, please help us to make clear.
Thank you very much for the help.
Best Regards
Alex
Conglin Tank
2007 Edition
Best Regards
Alex
Conglin Tank
RE: ASME U stamp Job or T Stamp Job
I believe Section XII is to be reserved for hauling cargo.
DOT is currently working to publish a rulemaking that will formally adopt Section XII and the NBIC into the federal regulations. See link below:
htt
Currently, ASME Code Stamped vessels (tanks) in transport service are stamped as Section VIII (U-stamped) vessels. Once Section XII is adopted, by the DOT (including the Jurisdictions) new vessels will bear a "T" Stamp, and repairs or alterations must be performed by a holder of a "TR" Certificate of Authorization.
All of this is still pending.
