Looking for macro to traverse configurations
I am looking for a macro to go from configuration to configuration and save a snapshot (jpeg) of each one. Is anyone aware of something like this?
RE: Looking for macro to traverse configurations
Quote:
SolidWorks API Help
Iterate Through All Configurations Example (VB6)
This example shows how to iterate through all of the configurations in a document and forcibly rebuild each one. It assumed that you have an active document.
CODE
' Forcibly rebuild each configuration
Option Explicit
Sub main()
    Dim swApp                   As SldWorks.SldWorks
    Dim swModel                 As SldWorks.ModelDoc2
    Dim vConfNameArr            As Variant
    Dim sConfigName             As String
    Dim nStart                  As Single
    Dim i                       As Long
    Dim bShowConfig             As Boolean
    Dim bRebuild                As Boolean
    Dim bRet                    As Boolean
    Set swApp = CreateObject("SldWorks.Application")
    Set swModel = swApp.ActiveDoc
    Debug.Print "File = " + swModel.GetPathName
    vConfNameArr = swModel.GetConfigurationNames
    For i = 0 To UBound(vConfNameArr)
        sConfigName = vConfNameArr(i)
        bShowConfig = swModel.ShowConfiguration2(sConfigName)
        nStart = Timer
        bRebuild = swModel.ForceRebuild3(False)
        Debug.Print "  Config       = " & sConfigName
        Debug.Print "    ShowConfig = " & bShowConfig
        Debug.Print "    Rebuild    = " & bRebuild
        Debug.Print "    Time       = " & Timer - nStart & " s"
    Next i
End Sub
That may give you a start.
I'm sure someone posted a complete macro a long time ago, but have had no luck finding it yet.
cheers
Thanks, CBL.
Actualy I've already found that example and modified it o my needs.
So do you now have a fully working macro?
Can you post for future reference? This comes up occasionally.
cheers
Here you go:
CODE
' Save each configuration as JPG
' It assumes a model is open and active.
Option Explicit
Sub main()
    Dim sFileName               As String
    Dim sPathName               As String
    Dim i                       As Long
    Dim bRet                    As Boolean
    Dim longstatus              As Long
    Set swApp = Application.SldWorks
    sPathName = "G:\Working\Design\JPG\"  'change sPathName as per your needs
        nStart = Timer
        'bRebuild = swModel.ForceRebuild3(False) 'Forcing the rebuild will slow down the process
        sFileName = sPathName & "A" & sConfigName & ".JPG" 'Use A, B, C, ... to save in different views
        longstatus = swModel.SaveAs3(sFileName, 0, 0)
    Next i
End Sub
