Problem with weld breads in Assemblies with Helixes
Good after noon, I have one assembly with a tube with a single loop, helix and swept, in the middle and a part on each end. I can use the weld bead on each end and get a weld and the is what I want. I have a second assembly with a tube and a double loop, one loop up and one loop down and made the same way, but when I try and put a weld bead on the ends, they fail, like when the countersink in the ends is to large, but I have made the countersink hole as much as .01 smaller than the OD of the tube. and still nothing. Any suggestions as to what I can do to geta weld bead on the double loop assemblies? Thanks you in advance for any assistance.
RE: Problem with weld breads in Assemblies with Helixes
Can you make copy of the finished single-loop part and convert it to a double-loop?
