compare steel types
compare steel types
compare steel types
Hi everyone,
I am building a magnet that will go into vacuum.  It must be small (chamber limitations) and reach 0.1T
As of now I am using steel 1018 but read in a journal that 1010 was used with better results.
I can't seem to find anywhere to compare these too steels (mu and other parameters) as well with other steels.
Question 1: anyone know where I can find such information?
I also found out that supermalloy has a very high mu. that would help me reduce the current I run thus reducing the heat created as a result.
Question 2: does anyone know if supermalloy can go into vacuum and if it can be shaped on a lathe machine?
thanks guys
RE: compare steel types
Is this for an AC or DC application?  If AC, then what frequency?
1010 will have a slightly higher magnetic output than 1018, becuase it has less carbon in it.  For most applications, you won't notice a difference.  There is data on this in the scientific literature, but probably scattered around a number of different papers.
Supermalloy can go into a vacuum, but it is processed as very thin sheets so you will not be able to shape it on a lathe.
Supermalloy will produce much less magnetic output than 1018 or 1010 steel, unless you are taking about an AC application.
thanks for the info.
It is for a DC application.
Do you (or anyone else) have a good idea for something else that I can use instead of 1018 with a higher mu?
also, do you know how much % of pure iron is in the 1018?
1018 steel will contain 98+% iron.
If you can afford it, Vanadium Permendur will have a higher output than iron/steel.  It's very expensive and you have to heat treat it to get maximum properties.
Dear yoavac,
I can offer Electrical Core Iron Rod (.02% max Carbon)  or Electomagnetic Iron (pure Iron) Strip (.008 max.% Carbon)  Either one will offer a very low Hc and high permability.
Let me know if I can help!
Lloyd
lloyd@cmispecialty.com
thanks guys, MagMike, i'm not sure I want to start dealing with heat treatment beofre I can use it.
but MagneticIronGuy, your ideas might work.
thanks a lot
