PDS Software for Plant Erection
http: //www.inte rgraph.com /products/ ppm/pds/de fault.aspx
Has anyone used this in conjuction with autodesk Inventor. What I mean is if we need to export the 3D models from Inventor to this PDS software, How to do about?
RE: PDS Software for Plant Erection
I don't have a clue how to import anything from Inventor.
"Pumping accounts for 20% of the world's energy used by electric motors and 25-50% of the total electrical energy usage in certain industrial facilities."-DOE statistic (Note: Make that 99% for pipeline companies) http://virtualpipeline.spaces.live.com/
Greetings
My client overseas strictly uses PDS. I wonder if it can open step files or even iges files.
If you guys have used PDS, can you File>open> and what and how many different types of file types it can open. Maybe I can send you a sample to check if it works without giving you much trouble, if its okay with you guys.
Thanks very much.
