survey data to auto cad
i have completed a survey with xyz co ords in excel or csv format, i need to uses auto cad(a full version) to display these points on a drawing with the level attached in text, i have downloaded rapidDXR 4.0 and varios lisp programs, and i still cant get the info displayed, is there a simple way that i'm missing to do this?
i appologise if this has already been answered, but i couldn't find any threads on this forum that helped.
thanks in advance
olly
thanks in advance
olly
RE: survey data to auto cad
are you looking for a script?
point
1,3,2.5
2,5,9
...etc
Check PDMODE and PDSIZE
L.
ADT 2004
the points are inside the *.dwg and now you want a text at every point with the values of the x/y/z axis.
Which lisp did you download?
ADT 2004
paid for the licence and it works a treat!
This thread points to a freeware download useful to write an ACAD script file from MS Excel
I've configured the routines in Excel to write a script that will write each point (using PDSIZE and PDMODE), Point ID Text, Point Level Text (each point is coordinated as 3D) and a sequential 3D polyline through the points (to help identify location). Other routines allow blocks to be inserted at a designated location and rotation from Excel.
I used this for about a couple of years now and proved very useful. Good luck...
