Where are commands in SEwST ?
My first question is :
In V20 I could pick 2 or more dimensions and then use
Edit > Properties to change them.
Now I can't find where this, or where an equivalent option is located.
There is a Properties area on the command bar but it's useless when editing a dimension.
Can anyone help?
Can anyone help?
bc.
2.4GHz Core2 Quad, 4GB RAM,
Quadro FX4600.
RE: Where are commands in SEwST ?
you find it here (Part, Sketch or Profile mode)
- customize QAT
- Pulldown --> EDIT
-> Add 'Edit Properties'
Close
It will be inactive as long as no dimension is selected
HTH
dy
I'm not going to tell them I've got the answer though - just see how long it takes for them to find it.
Looking at the pulldown list, all of the old style toolbars are in there!
I'll try and remeber to look in there first when I can't find something.
bc.
Quadro FX4600.
