Protect assembly when exporting
I have an assembly model in Solid Edge which I want to export to a .step file.
How can I export such to .step such that when someone opens it in Solid Edge they can only view the model as a whole, and not be able to select individual parts?
RE: Protect assembly when exporting
If it's not a big assembly you could do Insert > PartCopy of it into a part file, then STEP that.
I'm not 100% sure if it will work but it's worth a try.
bc.
2.4GHz Core2 Quad, 4GB RAM,
Quadro FX4600.
That worked like a charm! Thank you very much
Well it worked so thats cool however...
For complex geometry if often wont work, so you can't always rely on it.  Also when a colleague & I took this up with then UGS they discouraged it.
However, I've used it to my advantage before.
KENAT,
Have you reminded yourself of FAQ731-376: Eng-Tips.com Forum Policies recently, or taken a look at posting policies: http://eng-tips.com/market.cfm?
Yeah, on some assemblies it does not seem to work..
Did you ask UGS of an alternative way of doing it?
Problems are usually caused by assembly conditions such as edge-to-edge and edge-to-face coincidence.
If you avoid these you should be OK.
Bringing the assembly into a weldment might be another option.
bc.
Quadro FX4600.
We spent a bunch of time on this a while back and I don't recall coming up with a really good 100% solution.  I don't recall UGS/Siemans coming up with directly equivalent either.
Another way to the same end can be to create a simplified assembly that you then save as a part but you still face the same fundamental problems.
KENAT,
