missing property definition??
Hi everyone, my name is russel currently have a problem with my abaqus analysis. I run the job I've created for that model of vented brake disc rotor and get the following (very helpful) error message:
Error in job bos: 16235 elements have missing property definitions. The elements have been identified in element set ErrElemMissingSection.
Job bos: Solver Input File Processor aborted due to errors.
Error in job bos: Solver input file processor exited with an error - please see the data file for possible error messages if the file exists.
Job bos aborted due to errors.
Part instance: Part vented disc rotor-1
Number of elements : 16235, Analysis errors: 0 (0%), Analysis warnings: 11 (0.0677548%)
Any help would be greatly appreciated.
RE: missing property definition??
HTH
I have the same error. Its displayed ErrElemMissingSection even though i have assigned the section for the part. Please help. I've try to view the element set, and it is on the stringer that i've used. However i have assigned the section and check it again, and still, this error appear. Any suggestion will be great. Thanks in advance.
Good Luck,
Mohammad Shahbazi
www.OmranAfzar.com
the modified file is attached. happy submitting.. ;)
Good Luck,
Mohammad Shahbazi
www.OmranAfzar.com
Sharifah
