error message
error message
error message
Could anyone please explain why I would get this error??
Cast Iron tension local NR algorithm does not converge
Thanks in advance.
RE: error message
There is a singularity or a local min / max ambiguity in the Cast Iron constitutive law. The Newton-Raphson algorythm doesn't converge.
RE: error message
thank you. I found the problem. I had an error in defining the tension data of the material model.
Thanks again.
