Opto-Coupler pole in SMPS feedback
On page 12, 13 and 14 of AN1059 application note they do the feedback compensation for the L6561 flyback power factor corrector circuit.
****AN1059 Flyback PFC application note.
http://w ww.st.com/ stonline/p roducts/li terature/a n/5956.pdf
However, considering the equation at the bottom of page 14 (H(s)), or any other transfer functions listed, -None of them include the effect of the opto-coupler pole.
Also, the diagram at figure 15, (top of page 15) does not show the opto-coupler pole equivalent capcitor which should appear accross the Collector-Emitter of the opto transistor.
In relation to this, -pease may I quote from Basso's book, page 322.........
"Compensating the power supply without keeping in mind the opto-coupler pole position is useless. Always measure or compute the pole position and include it in the loop design process to avoid last-minute bad surprises"
The AN1059 application note clearly has taken no account of the opto-coupler pole.
Do you know how this can be so?
Thankyou very much for reading.
http://w
