cleaning carbon steel with hydrogen peroxide
I am trying to determine if it is safe/acceptable to clean carbon steel pipe with a hydrogen-peroxide and water solution.
Does anybody know the answer to this question? If a source where this is stated can also be included it would be much appreciated.
Thanks in advance,
- Jeff
Thanks in advance,
- Jeff
RE: cleaning carbon steel with hydrogen peroxide
Dik
http://nzic.org.nz/ChemProcesses/metals/8H.pdf
peroxide is a strong oxiadnt so what can you achieve is a corrosion and passivation of the metal surface.
as you can see there are many other methods to clean steel:
PRE-COMMISSION CLEANING
h
S
Corrosion Prevention & Corrosion Control
