linetype edge broken out section view
In a draft file the contour lines of a broken out section (view) are always as thick as the contour lines of the model. In essence very logical.
However, is there a way to change this? Let's just say I want the lines to be phantom lines
Evert
SoldEdge V20
Windows XP Pro
RE: linetype edge broken out section view
when doing the sketch for the broken out section profile
within the ribbon bar you find a pulldwon to change
the line type (next to Finish)
dy
That I know. I might have been not clear.
What I actually want is to change the line type of the contour lines of the finished broken out section view.
Evert
SoldEdge ST
Windows XP Pro
got it now. AFAIK it's the same line style that is used
for the drawing. So changing this will change all the
lines (view --> Properties --> Display --> Visible edge style
But you may check this
- selecet the view that contains the BOSV
- RMB --> Draw in View
--> select the function 'Edge Painter'
-> in the RibbonBar select 'User defined Edges'
set the activated Pulldown to the style you want
and then select the lines to change
when finished --> Return
dy
Thanks a lot.
This last option works perfectly
Evert
SoldEdge ST
Windows XP Pro
