cutting from coil
cutting from coil
There are lots of machines available which can laser cut individual stainless steel sheets into components. Does anyone know if there is equipment made which can accept coils of steel and cut componenets from them?
RE: cutting from coil
One approach would be a flying-optics machine, where the material could be fed in, the parts cut, and the scrap trimmed (probably by the laser) and dragged off by some unloading device.
Of course, a lot depends on the configuration of the parts to be cut- how they can be handled, etc.
For fairly thin sheet, even a hybrid machine (Amada's Pulsar) can be used- just need a good sag of sheet between the machine and the coil/leveller equipment.
cheers
Jay
