Unrotate global axis in upper geometry
Somehow the global axis of an upper product got rotated. I have other products tied in associativity and now Horizontal and Vertical is no longer the same as in the Upper Geometry.
My question is how can I change either the global axis of the upper assembly or change each of the parts to match the upper product?
RE: Unrotate global axis in upper geometry
I need some feedback before I make another suggestion
Do you have constraints between products? Are you designed in context of the assembly - basically a skeleton design?
Derek
http://www.eng-tips.com/viewthread.cfm?qid=224803
Cheers,
Mark
