Coldbox Washing-Aliminum acid wash
We have a coldbox - Aluminum material, for the application of natural gas treating. The coldbox is experiencing fouling and in need of cleaning. Because of the Aluminum construction, I'd like to understand if there is any special solvent can be used.
RE: Coldbox Washing-Aliminum acid wash
I've never known one to require a mineral acid cleaner but if one is required again compatibility with Aluminum is the main concern.
Basic cleaners that specifically inhibited for use with Aluminum are available if required.
Just be careful in cleaning any Aluminum tank/vessel as the conditions are right to generate a explosive gas mixture in the equipment.
