Design Criteria for PSV outlet Pipe (Hazardous Service)
We are in the process of designing an outlet pipe specifications for a PSV with hazardous Hydrocarbon service.
Should an unforeseen fire situation in the PSV outlet pipe have an impact on calculation of outlet pipe size??
Normally, what I believe that the flow rate, pressure and temperature in the outlet pipe of PSV should be considered crietria for deciding the specifications.
Any further opinions?
RE: Design Criteria for PSV outlet Pipe (Hazardous Service)
"Pumping accounts for 20% of the world's energy used by electric motors and 25-50% of the total electrical energy usage in certain industrial facilities."-DOE statistic (Note: Make that 99% for pipeline companies) http://virtualpipeline.spaces.live.com/
