how to fill high viscoity liquid in small gap
Hi all,
i got another problom here,
how can you fill a liquid( viscotiy is about 7000 cps) into a 0.2mm gap?
Thanks in advance.
Thanks in advance.
RE: how to fill high viscoity liquid in small gap
Perhaps vacuum to draw the liquid in?
the liquid will gets more viscosious when heated, it some kind of retainer compound. and vacuum is not feasibale.
for that viscocity 7000cps, will it flow though a needle?
Injection pressure should be no more than 1/2 the contact pressure of the dead weight. Might require a little trial and error.
I would ask the fool who designed it..
H
www.tynevalleyplastics.co.uk
Good luck,
Latexman
Cheers
Greg Locock
SIG:Please see FAQ731-376: Eng-Tips.com Forum Policies for tips on how to make the best use of Eng-Tips.
B.E.
"In this house, we obey the laws of thermodynamics." Homer Simpson
Depending how big this assembly is and how many you need to treat you might combine Ron's idea of sandwiching the parts with Berkshire's by adding the zerk to one of the plates. There is a bearing packer that uses this method to squeeze grease into bearings.
Griffy
Is the gap between two cylinders? Cap both cylinders. Put a measured quantity of liquid in the bottom of the outer cylinder and push the inner cylinder into place. Force the liquid into the gap between them.
Ted
Cheers
Greg Locock
