Need help finding replacement part
I have a transistor (picture ...drawn....see attachment).  I cant seem to find a replacement for this transistor.  Can someone help me?
Dave
RE: Need help finding replacement part
The casing is a fairly standard design, so what's special about the transistor? What's its function in the circuit, what voltage / current / frequency? The part number appears to be incomplete - not unusual on a surface mount device - so there just isn't enough to work on at the moment.
These parts are off a viewsonic VG150 inverter board.  I dont really know any more about the parts than this.
Hoping someone can help.
Correction......its a VG151 inverter board.
I did contact Viewsonic.  They were not much help at all.  They wanted to sell me a "new inverter".....all i want to do is fix the one i have for a lot less money.
I tried contacting the manufaturer in china but they have not responded to my 3 emails.
The package appears to be a SOT-89 or TO-283AA
Some suppliers have documents listing package markings. I suggest you do a search.
Thanks.  I have looked at the web sites which refer to surface mount device codes but i can not determine anything definative from them.  I guess the monitor is going in the trash unless i can figure it out.
Using a multimeter i ohmed out most of the inverter board.  I noticed one of the caps looked "different" so i started testing devices in that region.  A cap is bad (easy to replace) and the two devices i mentioned are bad and one of the transformers is bad.
I just looked at your pic... you do realize the tab and pin are supposed to be connected internally, right?
Dan - Owner
http://www.Hi-TecDesigns.com
yes.....the tab and pin 2 are connected/shorted.
Basically since i dont know what the devices are I compared devices on one side of the board (that are exactly the same) to devices on the other side of the board.   In doing so i foudn a few devices that were essentially shorted.  These are the devices i am trying to replace.
I just cant believe i cant find a replacement.  It really just frustrates me .
Thanks.
David
I don't think you understand... those pins are supposed to be shorted.  There's nothing wrong with them (at least due to the short you found).
Dan - Owner
Yes, on the "YB" device they are shorted.  But these are not the shorted pins i am referring to.
But thanks for responding.
I had a similar issue trying to find a part, all I did was contact either 247Components.com or digi-key.com and ask for assistance from one of their engineers. They tend to be pretty resourceful when they think there's a chance of a sale in it for them. Good luck
Jay,
That would be true if this were more than a one-off replacement and something more costly than a $0.05/pc transistor.
Dan - Owner
Just wanted to let you all know that i finally found the YB device.  It was from a company KEC in Korea.  I found the data sheet and then ordered a similar part from Digikey.
Put the part in and the LCD monitor worked!!!!!!!!!!
How did you find it?  Any tricks for the rest of us?
Z
persistance.........i got lucky and found a link which referenced the company.  The part in the link was not the part i was looking for but i searched the company's site and there it was.  Trust me i tried just about everything:  Forums, calling major electronic distributors, everything........just by luck i found the link.  I had almost given up but had 5min one day and started looking again and thats when i found the link.  Guess its good to put it down for a while and come back to things.
