API 682 plan apllication?
According API 682 flush plans, there are more than 70 of them? PLS can anybody can tell me which are the common use in chemical industry ?
RE: API 682 plan apllication?
Any advice, please let me know.
http://w
Or I recommend the course titled "Sealing Systems" on the attached link if your company will allow you to take it. If you are dealing with mechanical seals on a regular basis, it would be worthwhile and is fairly inexpensive, provided you are close to one of the listed training locations.
ht
htt
Mario Souza
Application & Product Engineering
WMF Solutions Brazil
http://www.wmfsolutions.com
A pressurised vessel used in conjunction with a double mechanical seal. If more heat needs to be removed a cooling coil and finned tubing can be used. A mechanical seal with a pumping scroll can be used if you have concerns over the thermal properties of your barrier fluid.
Your mechanical seal manufacturer should be able to guide you if you supply them with the correct product and process information.
11
52
53A, 53B, 53C
54
53B + 62 (Nitrogen quench to prevent icing on Ammonia)
11 + 62
02 + 62 (LP Steam)
Look at each application and apply the appropriate piping plan to provide long seal life
