Line thickness print problem - SW2009
Hi all,
My workstation was upgraded from SW2008 to 2009 SP2.0. A few problems encountered & they were fixed.
One problem really troubles me and the upgrade changed all line thickness by itself. This caused problem in printing & editing existing/ new drawings. In 2008, it was easy to change it & it is a one time deal. Also, setting is a gobal parameter, which I don't need to care for other dwgs. I went to print\ line thickness setting. In 2009, however, it only applies to each individual dwg, and need to do for each one. That is a pain!
Is there any way to get around this? Please advise.
engmech
engmech
RE: Line thickness print problem - SW2009
The other side of the coin is to fix the printing of existing drawings.
engmechs
Hardie "Crashj" Johnson
SW 2008 SP4
Nvidia Quadro FX 1000
AMD Athalon 1.8 GHz 2 Gig RAM
Yes, it does. It was found on other coworkers' machines too.
engmechs
