ASPHALT OPEN COOLING BOX
Dear all,
Asphalt in a 6" pipe is cooled by passing in an open box full of flowing water, a "cloud" of water vapors is rising from this box (the amount depends on weather).
How can we eliminate or reduce significantly the water vapors?
roker
roker
RE: ASPHALT OPEN COOLING BOX
Best Regards
Qalander(Chem)
But, It is a shame to waste all those BTUs. Carbon emissions or not, those BTUs are being paid for.
CJKruger's suggestion for an LP Steam generator is good, or you could pump the hot water to a preheater (economiser) for combustion air for the same burner that heats the asphalt.
