HELP - micron machining
anyone know how to measure and do micron / submicron machining.
If you know any shop, let me know. Our company works with a german company doing highly precision work. But our company need to develop US based supplier technical know how for our component supplier chain
Please help !!
we are dealing the tolerance .28mm +/- 0.02 mm
Please help !!
RE: HELP - micron machining
What type machining is required?
What materials?
What quanities?
You should choose where to post this (Optical or Mechanical, not both) since multiple posts are frowned on here.
As IRStuff said in the Optical forum, you'll need to provide more detail as what is being machined. We have vendors that we use for precision glass, vendors for precision plastic, and vendors for precision metal. I'm sure you could find many sources in a quick search but if you want recommendations you'll need to provide more information.
Harold
SW2009 SP2.0 OPW2009 SP0 Win XP Pro 2002 SP3
Dell 690, Xeon 5160 @3.00GHz, 3.25GB RAM
nVidia Quadro FX4600
www.lumenflow.com
20 um is only about 0.001", which is standard machining tolerance for placement of features. Surface finish should be orders of magnitude tighter.
Are you sure you have your units correct?
TTFN
We try 4 micron (that is .004 mm, .00015"), and the result is not as good as the German component. So, it will be roughly 2 micron (that is .002mm, .00008")
I thought it is crazy, but the company is manfuacturing ion mass spectrometry. Ion is much smaller than this size.
Please help. The boss struggles many years to develop US supplier. We want to buy more components from US supplier than foreign vendor.
The only way is to do optical inspection. if u have any recommendation for instrumentation measurement. Please advice.
FYI: 0.002 mm (2 micron) = 2000000 picometer
zinc ion is 134 picometer and
lead ion is 146 picometer
Electrode size / location placement fixture is already out of range for this application.
It looks like any optical component fabrication will have some technology transfer know how.
How long is the slit?
Maybe investigate acid-etching.
http://www.thorlabs.com/Navigation.cfm?Guide_ID=78
http://www.owensind.com/index.html
http://www.arcnano.com/page.php?pgID=19#13
Are you talking a rectangular slit with square corners or slit with square edges?
There are a couple of people that make apertures that we have dealt with and I'm trying to find them.
Also I try Monday to see if our people would like to do a outside job as it's very slow internally.
and slot deep is 1.00 mm (0.039")
Let me describe a little further
(1) The slit corner is important. The slit edge and the slit straightness from front to back is extremely important.
As the electrode burns the slit, it will create a funnel shape. The slit straightness along the 1.0 mm depth is extremely important. (and of course everything is in the micron range). We dont know how to minimize the funnel shape of the slit.
As the plunge electrode comes in contact with the invar, the center line of the slot to the metal center line is extremely important. We dont know how to hold the accuracy in the micron range.
Is there anyway to inspect the part easily or in process
process control?
The invar material with the slit will be glued to a piece of quartz. How can this gluing assembly process able to hold accuracy in micron range?
if the invar/quartz interface is skew in micron during the gluing process, the assembly will affect the system performace.
thank you
Cheers
Greg Locock
SIG:Please see FAQ731-376: Eng-Tips.com Forum Policies for tips on how to make the best use of Eng-Tips.
