Good design practices in permanent magnets motors
I want to analyze in ANSOFT Maxwell® several topologies for a linear motor using permanent magnets. I am a mechanical engineer and I am looking for a good reference regarding good design practices. Specifically, I want to know if a motor with coils and permanent magnets in the stator is something that can work or, at the other hand, somebody has discovered that this idea does not work at all.
RE: Good design practices in permanent magnets motors
But the electronic [Zero Cost] way to do the same thing is to shift the phase of the drive currents. A two to one speed increase can be easilly accomplished.
