Radius of Gyration
Radius of Gyration
The radius of gyration for a rectangular solid section is r = 0.3h. I am curious as to which "h" should be taken.
Say I have a rectangular column b = 200, h = 500, and a moment about the strong axis, would I take h = 500 or h = 200?
I am assuming h should always be about the weak buckling side, which is why h should be 200 mm.
CSA A23.3-04 does not clarify, it simply states "take r = 0.3h, h being the design dimension of the column)"
Any input is appreciated.
RE: Radius of Gyration
Clearly the radius of gyration of any section is (I/A)^.5, but there's nothing wrong with the down and dirty number of 0.3h...... especially if ACI allows it, right?!
Thank you for the helpful responses.
Put simply this way, in the AISC (ASD), when checking allowable compression stress, we have to check kx*Lx/rx & ky*ly/ry, Lx & Ly representing unbraced length in each direction respectively. And rx & ry are radius of gyration in the cooresponding direction, kx & ky are effective length factor in the corresponding direction. Therefore, for a rectanglar section a x b, h for cal r can be "a" or "b" depending the "direction" under consideration (either one could govern).
Which national code is CSA (I'll assume it is Canadian). The Australian concrete code also allows the radius of gyration to be calculated using 0.3*D where D is the direction under consideration. For you example, your column will have a stiff axis (bending the 500 dimension) and a weak axis (bending the 200 dimension). If you are designing your column for buckling in the weak axis, your dimension to use will be 200.
I = bh^3/12
A = bh
Divide I by A and you get:
I/A = h^2/12
Take the square root of this and you get:
SQRT(I/A) = r = SQRT(1/12) x h
The square root of 1/12 equals 0.288675 and some change, so they round it to 0.3 - an error of a little over 3%.
If you can't sleep at night with 0.3, use 0.288675...
If you "heard" it on the internet, it's guilty until proven innocent. - DCS
http://www.eng-tips.com/supportus.cfm
