Save Function Keys for all files
Hello, I'm having trouble with the function keys. Everytime i assign one and save it, and i open another file through ProjectWise, the key disappears! I think this is because perhaps the default location for the function key is the temp folder, and it gets cleared everytime i open a new file. Is there a way i can change the default folder for function key menus?
RE: Save Function Keys for all files
For example, the default function key file has F1 for help am I correct? This is represented correctly when I execute the bentley program from my desktop. When i use Projectwise to open up a .lo file, all the function keys go missing, no matter how many times i save them. They save to the \Bentley\Program\MicroStation\ folder as funckey.mnu, but they don't automatically load.
I hope that clears up my problem.
now If you want this to load at startup read the help file on how to edit the shortcut load with -w etc to load your macro upon loading ustn or pwise...
from the dos run cmd window in C:\Program Files\Bentley\Program\MicroStation
keyin ustation /?
to see all the keying options to change the way ustn runs from and icon
I can't tell you the options for pwise as I don't have it here but I used to use it at another company...
