Using Associative points
Software: NX4
I am trying to create a sketch plane on the ID of a conical surface.  For some reason I cannot create a point using an axis and the conical surface.
Any help would be appreciated.
RE: Using Associative points
opelgt21,
I tried to reconstruct what you described, and I think have succesfully done what you're trying to do.  Check out the attached model.
Basically, try creating a point as an 'Intersection' - choose the conical face and a construction curve.  Then you can create your sketch plane as 'Tangent' type, picking the conical surface and your point.
Are you putting the sketch on a plane, or flat face?
