Ending PhotoView 360 Session
Greetings all,
In the last day I have started to use PhotoView 360 and have been amazed at how much I get for so little effort. However, I cannot end a session or pick another SWX file to render without forcing an end to the PV360 session through the Windows Task Manager. I am on SP2.0 for both SWX09 and PV360. Have any of you experienced the same thing or have suggestions (besides use PhotoWorks instead)?
Thanks in advance,
- - -Updraft
Thanks in advance,
- - -Updraft
RE: Ending PhotoView 360 Session
haven't seen your issue and I am on SP2.
rfus
Thanks for looking at this. I was not aware about running them separately. When I just shut down SWX and then ran PV360 I got the same result; easy to use, but impossible to close or exit without Task Manager.
Does PV360 close through normal actions for you?
- - -Updraft
try a repair or reinstall? AV off? recommended GC drivers?
rfus
Of course, sometimes PV often decides to close itself...
- - -Updraft
