what's the type of this relay
the relay on the right is a normal relay.
the relay on the left has there terminals.the aux power is always on,and when "on" terminal is powered,the relay is activated.
what's the type of the relay on the left,and what's the difference between them?operate faster?
thanks.
thanks.
RE: what's the type of this relay
I've never seen a coil with three inputs, unless the aux power is a tap in the middle of the coil and can only provide holding power once the relay is closed, and needs the 'on' terminal to be powered to close. Then both '+' terminals would need to be turned off to open the relay.
Maybe it's not a real coil,just like a electronic relay,not elecmagnetic coil.the aux power is just for working.
when the "on" terminal is powered ,the relay close,and when the "on" terminal power off,the relay open.
Gunnar Englund
www.gke.org
relay back
relay schematic diagram
608/607/609pw is surge protection unit.
624/625/626xr is the relay ,what's the type?and why not use a normal type relay?
