Heat Loss vs. Time from a Refrigerator
So I'm just starting work for a non-profit trying to improve vaccine refrigerators for developing countries among other things.  This is the one project I've been given where I'm lacking any real world experience.
The basic problem is determining how long it will take for a given regrigerator with some "R value" insulation to have an increase in the inside temperature from 3 C to 10 C in the event of a power loss.
So I'm bench testing a small field refrigerator with thermocouples and varying the load in the refrigerators with water packs (no ice allowed because of vaccine freezing).  What I would like to do is also develop a rough equation for evaluating the temperature vs time change while varying:
1: Insulation (R value = 1/k)
2. Thermal load inside the small refrigerator
I know of the basic equation for conductivity through the refrigerator insulation
1.  Q = (k*A*dT)/x
and the equation for thermal capacitance of the load in the refrigerator.
2.  Q = m*Cp*dT (for each given item of different material)
It would be great to know for a given refrigerator if its more worthwhile to say, increase the R value of the insulation by 1.5 (just an example) vs. adding, lets say, 5 liters of ice packs.
For the sake of simplicity, just pretending there is a box with an r value and "x" number of water packs inside would be great simple example to begin with.
Wow, this ended up long.  Hopefully there is a good heat transfer saint out there.
thanks!
shawn
RE: Heat Loss vs. Time from a Refrigerator
The missing equations are Q = A*htc*dT for convection, and Q = emiss*A*Boltz_const*(Tb^4-Tr^4) for radiation, including solar loading.
You can do a crude model assuming a constant dT to the ambient, and see how many watts are been gained.
TTFN
