Solidworks Error Help
I am all of a sudden getting this error screen whenever i start SW or SW explorer. Iread that it can be caused by a sevice pack mismatch, and its used with pack and go. SW and PDM are all on SP 1.0. I've uninstalled and re-installed SW twice now and still the message. I had upgraded to SP 2.0, but it casued more problems than it solved. I wanted to roll back to 1.0 but i guess you cant. So after unistall and reinstall this error now plagues me. Thoughts?
I also have a macro button that i used to load and unload PDM. It used to work great, not if i use it to unload, it works. but if i try to reloadi get this error, and SW completely freezes. Any help would be appreciated. Thanks in advance!
Tony
RE: Solidworks Error Help
Tony,
Are you using AutoCAD DWG drawings?
Are you on Vista?
Bradley
SolidWorks Pro 2009 x64, SP2.0
PDMWorks Workgroup, SolidWorks BOM,
HP xw8600,
64-bit Windows Vista Business
Service Pack 1
Intel Xeon CPU, 3.00 GHz, 16 GB RAM, Virtual memory 166682 MB,
nVidia Quadro FX 4600 Driver 7.15.11.6956
no autocad installed, and xp64, but 32bit SW.
