577 volts to 480volts?
We are running 480 volt 3 pahse at our facility. We found a deal on a piece of equitment we need,but the motor is wound for 577 volts. Would it be alright to run this motor at 480 volts and expecting slightly more amp draw?
RE: 577 volts to 480volts?
If you are getting such a good deal, you'll be able to buy an autotransformer with all that extra money and boost the voltage up to what it should be.
Pretty sure you won't be happy running the 577 V motor at 480 V.
Bill
"Why not the best?"
Jimmy Carter
Every time you ask something about motors, you need to write all the details from the nameplate..
Zlatkodo
Motor current = 5 Amps
Boost needed = 120 volts
KVA = 5A x 120V / 1000 = 0.6 KVA
For this example motor you would need 2 boost rated 480:120 Volt transformers connected in open delta auto-transformer boost configuration. Dry type transformers may be mounted outside a panel or control enclosure. I have mounted them on the floor beside the motor at times.
Bill
"Why not the best?"
Jimmy Carter
