Contsraining Section Lines
I have a part made up of several lofted surfaces, and now I need a dimensioned drawing, with sectional views showing the dimensions contained in the original loft sketches. One problem is that I cannot project the spline geometry of my lofts into drawing-view sketches, so there's nothing to tie a sketched section-line onto.
How can I constrain my section-view definition line(s) such that they will 'perfectly' parallel the original loft-sketch planes?
RE: Contsraining Section Lines
Zip and attach if you can't figure it out.
I've been fighting this for two days.
ipt and idw file attached
