Combining Parameters in drawings
Here is the problem, we create several sheets per drawing and each sheet can have a different revision the problem is when ever we create a new sheet we need to add the following to the revision boxes "&dwg_rev#" We create the parameter in the part/assembly to coralate to the new sheet and add the revision level there. What I would like to do is have it so that the "#" sign is replaced with the current sheet number automaticaly when a new sheet is created. Is there a way to do this?
We are using Wildfire 3.0
Thanks for the help
Thanks for the help
RE: Combining Parameters in drawings
We use PDMlink and in order to pull the revisionfrom the database, we had to change all Pro/E drawings to be 1 revision per file instead of sheets.
Ben Loosli
