Avgas specifc gravity at lower temperatures
I need to find the specific gravity of avgas at low temperatures. Any thoughts where such data might exist?
Paul
www.ostand.com
RE: Avgas specifc gravity at lower temperatures
thread481-235995: AVGAS viscosity
"Pumping accounts for 20% of the world's energy used by electric motors and 25-50% of the total electrical energy usage in certain industrial facilities."-DOE statistic (Note: Make that 99% for pipeline companies) http://virtualpipeline.spaces.live.com/
The density, in particular, may vary significantly from one batch of fuel to another and is a reason for segregation of fuels by batch to ensure the correct density values are used when computing fuel loads.
Still, if you have a true density for the fuel batch then you can find the density at other temperatures using the Density 12Mb.xls spreadsheet at the same location http://www.viscoanalyser.com/page8.html.
JMW
www.ViscoAnalyser.com
I did find this though, if anyone is interested.
ht
Paul
www.ostand.com
