ACI-530.1 3.3 B.
ACI-530.1 3.3 B.
ACI-530.1 3.3 B. Placing mortar and units
b. Unless otherwise required, tool joint with a round jointer when the mortar is thumbprint hard.
Are veneered (sheet-rock, brick, whatever) CMU walls exempt from joint tooling?
RE: ACI-530.1 3.3 B.
striking is necessary, tooling is desirable
Ron:
What kind of waterproofing issues arise with untooled joints?
i think of it like poking holes in flashing...is it highly likely that the inside will flood from this? no. but is it possible that problems could arise? absolutely. it's simply much easier to follow aci, tool the joints, and do all the other things that are recommended/required.
msucog's post explains it well.
