Loft problems
Loft problems
Anyone know why all of a sudden "edges" are now appearing on my loft? They are indicated by the "no" symbol in the image. They are where I have my guide curves (the 2 you can see and the symmetric ones on far sides). They have not been showing up and now all of a sudden they do and they essentially bisect the surfaces/faces they are causing problems.
RE: Loft problems
Rob Stupplebeen
RE: Loft problems
RE: Loft problems
RE: Loft problems
RE: Loft problems
Assuming that easy fix does not work are you using a surface or a solid loft? Could you do a screen capture of the loft while you are editing so we can see the options and the selected curves? Please label them if it does not come across clearly.
I would use guide curves at all the corners not the middle of the surfaces but I do not think that your method is wrong just not my way.
I hope this helps.
Rob Stupplebeen
RE: Loft problems
But here is what worked (or got it back working like it was). I remade the bottom (larger) profile, and the little corner radius/blend went away, allowing me to keep the merge surfaces checked and eliminating all the other stuff that unchecking was doing.
If you have any suggestions I'd love them. I dont really know anything about surface lofts.
Thanks again for all your help on this. Right now Im knocking on every piece of wood I come across hoping that that problem doestn arise again.
RE: Loft problems
this may be your problem.
rfus
RE: Loft problems
RE: Loft problems
Are all your guide curves straight? If so you can probably do a surface sweep with one of your loft sketches as a path and one as a guide curve.
Hope this helps.
Rob Stupplebeen
