Datum Box SW2009 SP2.0
We recently installed SW2009 SP2.0, when inserting a new Datum or Feature Control the extension line is thick line, and the Feature Control box has a thicker line on the last box has anyone else seen this with SW2009?
Terry
Terry
RE: Datum Box SW2009 SP2.0
The settings are the same as SW2008. The lines were fine in SW2008. The line wt setting are .007.
Here's the work around until then.
Go to
Tools
Options
Select: Documents Properties
Select: View Labels
Expand View Labels
Select: Deatils
Look for Border
Change the line wt to .0071
Hope this will help others
Terry
