Smart questions
Smart answers
Smart people
Member Login
Join Eng-Tips now!
Join Eng-Tips
LINK TO THIS FORUM!
Just copy and paste the
code below into your site.
Partner With Us!
Partner Button
(Download This Button Today!)
Feedback
"...keep up the good work with this forum, I think this is the best one around. ...you actually try to help people learn for themselves. ...I commend you on providing a very good, open learning atmosphere, where usually egos are left behind..."
Geography
ly1phil (Mechanical)
28 Jan 09 12:46
I'm trying to put together a maintenance schedule for a 5-blade Kaplan turbine unit.  I've gone through the FIST manuals (U.S. Bureau of Reclamation) and some manufacturers manuals, but was wondering what type of services other Kaplan units undergo at different facilities.  I would appreciate and information pertaining to the maintenance of Kaplan turbines and/or lists/schedules that you happened to come across.
Thanks in advance!
Phil
wbd (Electrical)
30 Jan 09 7:31
Is this a moveable blade Kaplan?
3 Feb 09 15:17
Yes it is a moveable blade Kaplan.
wbd (Electrical)
3 Feb 09 20:48
I have two kaplans with moveable blades about 1990 vintage.
Yearly, we inspect:
blade to turbine case clearances, open and close
blade smoothness of operation
wicket gate close tightness
wicket gate operation
marine bearing clearances
oil in hub
blade transmitter calibration
wicket gate transmitter calibration
blade and wicket gate timing
torque check blade bolts
that is mainly it inside the turbine and then all the auxiliaries.
4 Feb 09 12:15
Thank you very much for sharing this information.
4 Feb 09 12:17
Do you perform any testing/inspections beyond the annual checks? Such as during major overhauls every 5 , 10 yrs?
wbd (Electrical)
4 Feb 09 15:11
The only other long term item is replacing the 4 sets of o-rings on each blade on a 5 yr interval, along new seals in the wicket gate hydraulic cylinders.
MikeHalloran (Mechanical)
10 Feb 09 13:30
I stood on a Kaplan blade inside the Saunders/Moses dam:
http://www.flickr.com/photos/pcellis/6227574/in/set-155511/
forty+ years ago.  They were in the process of hardfacing all the blades.  I have the impression they did it to every unit every couple of years, just to keep up with erosion from cavitation.
Mike Halloran
Pembroke Pines, FL, USA
Close Box
Join Eng-Tips® Today!
Join Us             Close
