Flexible components in V5r18
Is anyone having issues with flexible components not acting the same in v5r18 as in earlier releases?
When we open an assembly in r18 that contains flexible components created in r16 our whole assembly wants to turn flexible instead of the component only. We find that we have to turn off, then update each one when there are changes being made to the flexible component. This is new behavior in r18. We can get it to work but is very time consuming, Any ideas???
RE: Flexible components in V5r18
Derek
Derek
I now run SP7 Hot Fix 6 and it solved all the problems.
