Reservoir routing - hydrological problem
I have a project involving the determination of a 100-yr storm peak flow. The watershed has the following characteristics:
Area = 8.7 km2 (3.35 mile2)
Average slope = 13.1%
% woods = 67%
% pasture = 3.4%
% residential areas = 12%
% swmamps = 2%
% lake = 15%
I have a CN number for every subbasin.
I'm thinking of using a SCS Type II storm (6 hour, 12 hour and 24 hour) and compare the results.
My problem is the 15% of lake... Actually the lake is at the downstream end of the watershed (see the file attached).
I have the volume of the lake (1 250 000 m3.)
But regarding the reservoir routing... I'm quite lost.
What should i do to get a good estimate of the peak flow at the downstream end of the lake (where there is a small dam)?
Thanks for any clue regarding the method i should use for the reservoir routing!
% woods = 67%
% pasture = 3.4%
% swmamps = 2%
% lake = 15%
RE: Reservoir routing - hydrological problem
2) The dam would normally be modeled as a weir outlet on the pond.
3) You will need to have some stage-storage information above the weir crest (such as contours) in order to do an accurate routing.
4) If there is a pre-storm outflow from the lake, you will need to incorporate this as a base flow and/or starting elevation. The exact mechanism varies depending on the software you use.
You also need to allow for the direct precipitation on the surface of the lake. This is generally done by including the surface "runoff" using a curve number of 98+
Peter Smart
HydroCAD Software
www.hydrocad.net
This is precious informations
I would tend to use a very short time.
Correct?
Peter Smart
HydroCAD Software
www.hydrocad.net
I beleive there was a recent thread on this topic...
Peter Smart
HydroCAD Software
www.hydrocad.net
Mike McCann
MMC Engineering
Peter Smart
HydroCAD Software
www.hydrocad.net
If the structure is in the FERC network of dams, there could be enough time to draw the reservoir down prior to the storm, but that could be a luxury here. Even the FERC and Corps models are not perfect as the recent storms in the Northwest here proved recently. I would be conservative and design as if there is no storage. There could be a backwater effect, and I might yield on that issue, but not the available storage.
Mike McCann
MMC Engineering
Even when the initial WSE is above the spillway, the storm will increase the WSE even further, and this increase in storage will cause attenuation of the peak flow.
This effect can be simulated with a reservoir routing, based on the dam's stage-discharge relationship, and the stage-storage relationship as the water exceeds the spillway. A narrow spillway will "hold back" more water and produce more storage and attenuation than a wide spillway.
Peter Smart
HydroCAD Software
www.hydrocad.net
Mike McCann
MMC Engineering
I am assuming that the reservoir is full (i.e at the top of the crest of the small dam at the downstream end).
But combining a 100-year/6-hour SCS II storm + a full reservoir might be too conservative?
We don't have any legislation in here (Canada *sigh*) regarding those issues.
On the other hand, if the level-pool assumption is not met, then a backawater analysis would be required. This would be the case with a dam across a river, but that's not how I interpreteed the question at hand.
"But combining a 100-year/6-hour SCS II storm + a full reservoir might be too conservative?"
If the lake is normally filled to the spillway, this does not seem overly conservative. But it's really a matter of the standards you are trying to meet, and the downstream consequences of any increase.
Peter Smart
HydroCAD Software
www.hydrocad.net
Taken from the FERC:
htt
2-4.1.2 Guidelines for Initial Elevations
Specific guidance for establishing the initial reservoir elevation during the PMF is provided
in Section 8-3.1 of Chapter VIII of these Guidelines. This criteria should also be applied to
routing the IDF when the IDF is less than the PMF. In general, if there is no allocated or
planned flood control storage (e.g. run-of-river), the flood routing usually begins with the
reservoir at the normal maximum pool elevation. If regulation studies show that pool levels
would be lower than the normal maximum pool elevation during the critical IDF season, then
the results of those specific regulation studies would be analyzed to determine the
appropriate initial pool level for routing the IDF.
Failure is catastrophic.
Mike McCann
MMC Engineering
Starting with the reservoir at full storage capacity (or in terms of highest elevation) and using the SCS type II or constant intensity repartition of the storm, the lake is emptied quickly after the reservoir routing analysis starts as the discharge of the dam at this full storage capacity is quite high (could be something else in another projet).
So... when it comes to calculate the Water Surface Elevation related to this flood, the starting elevation used in the routing analysis is the critical one (highest).
Am i missing something here... It really depends on this elevation choice.
A reservoir will generally produce peak attenuation even if it is filled above the spillway prior to the event. Depending on the surface area, there can be considerable storage as the level rises just a few inches above the spillway, and this storage will result in peak attenuation. You will see this effect with a standard level-pool routing.
Sure, you'll get more attenuation if the reservoir is drawn-down prior to the event, but I was assuming that it is full, and in fact overflowing, prior to the event in question.
To model this in HydroCAD, you can set a starting elevation above the spillway, and then select "Automatic Base flow". This will calculate and apply an additional base-flow as required to keep the pond at equilbrium with this pre-storm outflow.
Peter Smart
HydroCAD Software
www.hydrocad.net
Regulators will let you get away with a CN of 98 for the lake area itself, but the appropriate thing to do is set it at 100 if it doesn't break your software. The evaporation from a lake for design storm is negligible over that time scale, especially during a storm. But as has been mentioned above, the differences aren't really worth arguing about.
Always always always start your reservoir routing at the control elevation of the dam. (That'd be your lowest orifice or your spillway / etc) There are two exceptions I can think of, and they're both driven by the regulatory agency you're doing your work for, so you'll know if they're meaningful.
Some regulatory agencies like to have stormwater treatment ponds that capture and infiltrate water into the ground. (e.g. Florida WMDs) In these cases, you're usually required to prove that this dead storage retention volume is recaptured between storms, by showing infiltration calcs and water table elevations and whatnot. Some regulatory agencies (some munis in Georgia) like you to start higher than the lowest control, if the lowest control is a long term bleeder device for water quality and they don't trust that you'd have all the volume available during the flood routing.
The elevation you start your reservoir routing at is important. Folks get sued over this kind of stuff. I was an expert witness against another engineer who screwed this up badly and was exposed for a lot of damages because of it.
On backwater, there's two issues. One is whether folks upstream of the reservoir get flooded by the reservoir level increasing. For any reasonably sized application just assume the water is flat across the reservoir's surface. The other issue is one engineers also screw up quite a bit in some areas of the country, and that's tailwater on your outlet control structure. This is a big deal in Florida since the discharge from series of connected ponds can be effected by the downstream pond, because the driving head is not just upstream head, it's head differential. You need time series routing tools for these, such as ICPR or XP-SWMM. In regions of the country where you aren't likely to have tailwater on your outlet control system, engineers have grown used to using simpler tools that only consider upstream head. (Hydraflow ... ugh, what a piece of crap) Engineers who don't realize the difference, and use the latter to design the former situations can get into big big big trouble, because their pond doesn't draw down like they expect it to, and stages higher than they expect. Again, fodder for lawsuits.
My comments are largely for small reservoirs in land development, or regional reservoirs that are not directly managed. I'm not talking about municipal drinking reservoirs or other things that are managed by some dude at a control desk. How you do hydrology for those sorts of applications is much more complicated, and I assume the top poster isn't asking about those on a forum such as this.
As always, go with widely accepted practice for your region (if such a thing exists) because hydrology is very, very regionally influenced.
HEC HMS doesn't support 100... I guess 98 and specifying 0 inches of Initial Infiltration is something suitable.
"The elevation you start your reservoir routing at is important."
I'd tend to start it to the normal pool elevation.
I think that assuming full storage prior to a, let say, 1000-year storm is really conservative.
Indeed this is related to a small reservoir where 2d hydraulic modeling would be... too much.
Peter Smart
HydroCAD Software
www.hydrocad.net
The regulatory agency in charge of reviewing a similar project is asking me to find another way to calculate the outflow from a dam.
I did use HEC HMS and reservoir routing.
They say that they don't get the same outflow using flow rate recorded at a gage station located on a river near the study area and transposing it for the basin related to this study.
I really think that such a comparison is not possible considering the important storage of the lake...
Performing my analysis, the WSE of the lake increased of almost 2' during the simulation. The outflow from the dam was then calculated with standard weir equation = CLH^1.5 = 3.1(8.2)(2)^1.5 = 72 cfs.
Someone have any idea of another method to calculate the outflow from the dam?
Please don't say "Rational Method".
Second: Since you are modeling a complex 3.5 SM watershed, the margin of error will be significant.
How large is the difference? I would verify all the input data (including the rainfall depth and distribution) to look for errors or reasonable adjustments that would bring the model into closer agreement with the gauge.
Peter Smart
HydroCAD Software
www.hydrocad.net
And a statistical analysis (e.g. using log-Pearson II distribution) to determine a 100-year flow rate.
Then they are using the ratio of basin areas to transpose this flow rate to the area of study.
I'm using a 24-hour SCS-II 100-year rainfall.
This particular method of comparaison doesn't make any sense to me (!?)
Yes the rating curve take in account effective length as state in Design of Small Dams (USBR, 1987). No Submergence effects.
Anyway, my question was more related to a validation method fur a project like this one? Another method than using HEC HMS and reservoir routing.
Perhaps you could ask them to provide their inflow hydrograph and plot the two and compare the differences.
What to do now (apart from teaching them basic hydrology).
A way to validate the max increase of 0.5 m in the lake.
http://www.stormh2o.com/sw_0607_voodoo.html
