Smart questions
Smart answers
Smart people
Member Login
Join Eng-Tips now!
Join Eng-Tips
LINK TO THIS FORUM!
Just copy and paste the
code below into your site.
Partner With Us!
Partner Button
(Download This Button Today!)
Feedback
"...I love the structure of the site. You start at the top, and drill down to what you want. Maybe I've been using Unix too long... :-) "
Geography
grunt58 (Mechanical)
28 Jan 09 11:05
I was wondering if there is a base line number/average for vacuum I can use to help calculate the size and amount of vacuum cups one would need.
I know it depends on leakage, distance, # of cups, psi applied etc. but I was hoping there is some sort of baseline I can use as a starting point.  I'm trying to make a force calculator with excel or maybe there is already one on the internet.
With 87 psi how much vacuum (inHg) could I pull.
Thanks for any help....
Grant
Applications Engineer
SW2008 X64 SP 3.1
Dell Precision T5400
Nvidia Quadro FX 5600
Xeon 2.5GHz Quad Core, 4GB RAM
XP Pro X64 SP2.0
itsmoked (Electrical)
28 Jan 09 16:06
You need to hunt around and find the "air eductor" or "venturi" you are going to use to create a vacuum from "87 psi".
Example:
http://www.foxvalve.com/index2.html
Then it's just the surface area verse the vacuum pressure that gives the cup's lifting ability.
Keith Cress
Close Box
Join Eng-Tips® Today!
Join Us             Close
