Adhesives Question
Adhesives Question
I have a problem with an aircraft door seal that's disbonding. The door is a composite door with a rain seal around its outer edge. The current seal is an AMS 3195 silicone rubber strip, bonded to the door with MIL-A-46106 Group I Type I silicone adhesive. I'm not an expert on adhesives, but this stuff does not seem terribly strong or durable.
Can anybody suggest a better adhesive ?
I've been through ASTM D 6465, and while that's great for the initial design, I'm looking for something a little more specific, i.e. actual manufacturer and part number, that sort of thing. Any guidance you folks can give me will be appreciated.
RE: Adhesives Question
Then again, my sample size is pretty small (3 out of a fleet of 20-odd aircraft).
Not sure about the primer, will check.
Regardless, if the adhesive selection is even remotely appropriate for the application adhesive failure almost always comes down to improper surface preparation.
With a composite I would suspect contamination from mold release or amine blush.
Try to "rough it up" with some 120-grit sandpaper, then wipe it down with IPA before bonding.
Wes C.
No trees were killed in the sending of this message, but a large number of electrons were terribly inconvenienced.
