how to convert rotary motion to lin
how to convert rotary motion to linear motion
rotary motion 7 degree per pulse in stepper motor
to linear motion 1mm
RE: how to convert rotary motion to lin
360*(1/(5Pi)) = approx. 22.91831°
I don't use steppers, but I'm assuming that each 'step' is 7°. If this is the case - you'd need approx. 22.91831°/7° = approx. 3.27404 steps.
If so then the pinion needs to have a pitch dia.
of 8.1900mm.
linear movement per. degree of rotation. A screw for
this application would need a pitch of 51.42857142875...
mm., an infinitive number.
gearguru
apologize me : "ARE YOU SURE YUR STEP IS 7 DEGREE"
PLEASE CONFIRM THIS VALUE
If I'm wrong, apologize me again.
Pardal
